Hi guys, long time lurker first time poster
So after flashing the latest release of MerlinWRT, I've been experiencing intermittent router restarts for no apparent reason. Internet access is disrupted and the uptime on router is restarted. I've noticed in the system logs that there weren't any informative errors there.
What I did notice however many days of logs disappeared and the last line of the log before the restart happened is from weeks ago. Everything up till that point is gone, so there's a gap from that specific date till the router restarts again. I see a "time disparity error" in the newly booted logs and have no idea what to do to fix it. I'm using the same NTP service from before the firmware upgrade. The router time is not out of sync with system time or NTP time. Any help is appreciated. Removed IPs for privacy.
May 5 13:05:54 CakeQOS-Merlin: /jffs/addons/cake-qos/cake-qos (pid=3259) called in unattended mode with 1 args: startup
May 5 13:05:54 CakeQOS-Merlin: Cake QoS is not enabled. Skipping CakeQOS-Merlin startup.
May 5 13:05:54 FlexQoS: /jffs/addons/flexqos/flexqos.sh (pid=3319) called in unattended mode with 1 args: -start
May 5 13:05:54 FlexQoS: Adaptive QoS is not enabled. Skipping FlexQoS startup.
Jul 19 21:17:59 inadyn[3459]: In-a-dyn version 2.9.1 -- Dynamic DNS update client.
Jul 19 21:18:00 inadyn[3459]: Update forced for alias all.dnsomatic.com, new IP# xxx.xxx.xxx.xxx
Jul 19 21:18:01 crond[1557]: time disparity of 2212332 minutes detected
