AX88U AsusWrt-Merlin 384.19 default nvram requires JFFS re-format
dredekop
I've noticed that on my AX88U with AsusWrt-Merlin 384.19 (latest release), the JFFS partition needs a *reformat* after a 30-30-30.
Is that a simple default NVRAM setting that may need a tweak?
This screenshot shows what I get on first login, and the only way I can make it usable is to first format jffs on next reboot, and then reboot.
Thanks to Merlin for all the awesome work!
det721
Part of the Furniture
30-30-30 Does nothing on Asus routers. Next time don't waste your time. It's the same for my AX58U after flash JFFS always says unmounted.
El Mariachi
Its after any sort of reset on the latest merlin stable build. Just hit format JFFS and reboot after a reset and that error goes away.
dredekop
You're right, 30-30-30 does not work on stock firmware. Then the ASUS reset process must be used.
However, 30-30-30 works just like it always has, once Merlin firmware is installed.
L&LD
No, it doesn't work with RMerlin installed either.
