brianmsailing
Can someone help understand what these errors are.
Jun 20 07:31:13 miniupnpd[31514]: version 1.9 started
Jun 20 07:31:13 miniupnpd[31514]: HTTP listening on port 44081
Jun 20 07:31:13 miniupnpd[31514]: Listening for NAT-PMP/PCP traffic on port 5351
Jun 20 07:31:13 miniupnpd[31514]: shutting down MiniUPnPd
Jun 20 07:31:14 miniupnpd[31516]: version 1.9 started
Jun 20 07:31:14 miniupnpd[31516]: HTTP listening on port 49887
Jun 20 07:31:14 miniupnpd[31516]: Listening for NAT-PMP/PCP traffic on port 5351
Jun 20 07:31:14 RT-AX88U: start https:8443
Jun 20 07:31:14 RT-AX88U: start httpd:80
Jun 20 11:31:22 hour monitor: daemon is starting
Jun 20 08:27:57 acsd: acs_idx_from_map(198): cannot find the mapped entry for ifname: eth7
Jun 20 08:27:57 acsd: acsd_main_loop(506): cannot find the mapped entry for ifname: eth7
Jun 20 08:34:51 acsd: acs_idx_from_map(198): cannot find the mapped entry for ifname: eth7
Jun 20 08:34:51 acsd: acsd_main_loop(506): cannot find the mapped entry for ifname: eth7
Jun 20 08:38:21 acsd: acs_idx_from_map(198): cannot find the mapped entry for ifname: eth7
Jun 20 08:38:21 acsd: acsd_main_loop(506): cannot find the mapped entry for ifname: eth7
Jun 20 08:39:01 acsd: acs_idx_from_map(198): cannot find the mapped entry for ifname: eth7
Jun 20 08:39:01 acsd: acsd_main_loop(506): cannot find the mapped entry for ifname: eth7
Jun 20 08:40:16 acsd: acs_idx_from_map(198): cannot find the mapped entry for ifname: eth7
Jun 20 08:40:16 acsd: acsd_main_loop(506): cannot find the mapped entry for ifname: eth7
Jun 20 10:45:18 acsd: acsd_main_loop(781): sync_id: 28876, status:1, misc.error/abort
Jun 20 10:59:07 kernel: FPM Pool 0: invalid token 0x00a38000 freed
Jun 20 12:03:35 acsd: acs_idx_from_map(198): cannot find the mapped entry for ifname: eth7
Jun 20 12:03:35 acsd: acsd_main_loop(506): cannot find the mapped entry for ifname: eth7
Jun 20 12:03:36 acsd: acs_idx_from_map(198): cannot find the mapped entry for ifname: eth7
Jun 20 12:03:36 acsd: acsd_main_loop(506): cannot find the mapped entry for ifname: eth7
Jun 20 12:03:38 acsd: acs_idx_from_map(198): cannot find the mapped entry for ifname: eth7
Jun 20 12:03:38 acsd: acsd_main_loop(506): cannot find the mapped entry for ifname: eth7
Jun 20 12:03:40 acsd: acs_idx_from_map(198): cannot find the mapped entry for ifname: eth7
Jun 20 12:03:40 acsd: acsd_main_loop(506): cannot find the mapped entry for ifname: eth7
Jun 20 12:03:41 acsd: acs_idx_from_map(198): cannot find the mapped entry for ifname: eth7
Jun 20 12:03:41 acsd: acsd_main_loop(506): cannot find the mapped entry for ifname: eth7
Jun 20 12:03:42 acsd: acs_idx_from_map(198): cannot find the mapped entry for ifname: eth7
Jun 20 12:03:42 acsd: acsd_main_loop(506): cannot find the mapped entry for ifname: eth7
