have this message on a loop. Restarted, reset, factory defaulted, used some other suggestions from this forum for similar reports, turned on/off smartconnect... no change
Oct 24 23:19:34 acsd: eth7: Selecting 2g band ACS policy
Oct 24 23:19:34 acsd: acs_get_country(392): get country on eth7 returned -19.
Oct 24 23:19:34 acsd: acs_start(408): eth7: Failed to get country info
Oct 24 23:19:34 acsd: acs_get_rs_info(220): failed to get chanspecret code: -19
Oct 24 23:19:34 acsd: acsd_chanim_init(118): eth7: failed to set chanim_sample_period
Oct 24 23:19:34 acsd: acsd_chanim_init(127): eth7: failed to set noise metric
Oct 24 23:19:34 acsd: acs_start(432): chanim init failed ret code: -19
Oct 24 23:19:37 acsd: acs_check_cap(334): eth7 Error -19 in getting cap
symptoms: random wan disconnect with a red light, requiring manual reset
suggestions?
TIA
suggestions?
TIA
