Hi all
Just got a AX88U and so far setup has been fine. But I ran into a issue. My laptop runs a Intel dual band 1x1 3165 adaptor. I can connect to the router, but speed tests are 11 mbps only,. I updated the driver to 19.51 as well and it went up to 17 mbps, not any better. Im not getting it. I changed channels, with/without AX, steady at 80hz, and still not seeing any change on tess.
However, upload is about par to what i should have.
I'm guessing its a WiFi card issue? Or can anyone suggest a better solution? Thanks
