AX88U stops working
blk96ss
Good day all,
I've owned this AX88U router for a couple of years now. It recently started acting up. Devices that are hardwired and on Wi-Fi will lose internet connection randomly. Sometimes just the hardwired Fire TV cube in my room only while everything else works fine. I use ATT as my internet provider and have a nearby fire stick connected to their gateway that has never lost internet connection. I have attached a syslog that I saved today when it happened again.
Thank you in advance for any input.
A crash at 13:45:13, but nothing in the log as a reason.
Clearly a lot of your devices are struggling to stay connected, being at the coverage limits. What firmware and when was the last time you did a reset? A power reset would be a good start (just pull the plug, wait 10 seconds and power up).
The router is on Merlin 3004.388.10_2 and I have it running on mesh mode with a ac68u connected in Ethernet backhaul mode. I recently did a complete reset to see if it would fix things but apparently not.
