bradbort
After experiencing way too many firmware months a couple of months ago, I tried the AX88U again today . I installed the latest M. firmware, and everything worked without changing any of the defaults from Merlin.
(Last time I was having problems with many legacy 5g clients, and the 2.4 networking was not even showing up, so after a couple hours of futzing, I reinstalled my ac88u.)
While poking around in the defaults Merlin installed, I noticed that mode was set to N/AC/AX, but wifi 6 mode was off, as was 160mhz. I turned them both on, and promptly lost all my 5G network connections, including my dell XPS which supports wifi 6. I rolled back the changes, rebooted the router and....the 5G light on the router would not return! No joy. No 5G anywhere.
In installed the latest stock asus firmware. Still no joy, until I set wifi6 mode to off, and no 160mhz and rebooted. Now, everything seems to be working fine....but.....
Does this mean I'm just using it as an AC router? What is odd, is that my major AC clients seem to be running a bit faster, but my one wifi 6 client (Dell XPS 13 will "killer wifi 6 card") is still running at the same speed it was with the AC88U.
What caused my 5G light to go our with the last changes with the merlin firmware? Should I give that firmware another go? Will I ever be able to run my AX router in AX mode without causing all sorts of legacy client problems?
Thanks for any insight folks can give me!
Brad
Can anyone help me figure out what is really happening? Why does turning on wifi 6 kill most of my 5G clients (including smart TV).
Brad
