AX88U thermals
Logi
Does the AX88U experience the same thermals behavior of higher CPU temperature, when devices are connected to the Ethernet ports in the back of the router, like the AX86U? I have seen a difference of 5-8C when no devices are connected vs 4 devices connected, even with only 1 device connected, the CPU temperature will be 3-5C more with the AX86, thanks
I would think this is expected. 5-8C more doesn't say much. What is the absolute temperature?
With more options (software and hardware) connected and enabled, the device will have a higher temperature, as expected.
