ax89x mesh or ax6000 3 mesh setup
rwijnhov
In my country both the ax89x and the ax6000 are 250$. I want to replace my 3 mesh ac86u system with these. What to buy:
3x ax89x
3x ax6000
1x ax89x + 2x ax6000
With an sfp+ to rj45 converter you can use both 10g connections on the ax89x.
What would you do?
Could you please give complete model numbers?
If you're talking about the GT-AX6000, you may be able to upgrade your network substantially with only two (or even maybe, one).
Of course, no 10GbE connections, but having 3+ years newer hardware is worth it (to me).
And the other router? :)
Just bought the gt-ax6000 will set that up as my main router. Then I will use the ac-86u as mesh routers. Will see how it goes.
If that RT-AX89X really has 8x8:8 5GHz RF design and the faster 2.2GHz Quad-Core CPU, that is the one I would be using as the main router.
