AX92U drops connection and log error
meik19081999
Hello snbforum,
I set up 3 AX92U in a mesh configuration, but either the connection is unstable (no communication via teams-call possible) or it completly drops the wifi.
So far I've updated the firmware, factory resetted everything and set it up from scratch. Also I seperated the 2,4ghz 5-1ghz and 5-2ghz network with three different SSID's. Smart connect is also disabled.
The weird thing is my Log with the same message repeated all the time:
Sep 21 16:29:43 acsd: acs_check_cap(334): eth7 Error -19 in getting cap
Sep 21 16:29:43 acsd: eth7: Selecting 2g band ACS policy
Sep 21 16:29:43 acsd: acs_get_country(376): get country on eth7 returned -19.
Sep 21 16:29:43 acsd: acs_start(408): eth7: Failed to get country info
Sep 21 16:29:43 acsd: acs_get_rs_info(226): failed to get obss_coexret code: -19
Sep 21 16:29:43 acsd: acsd_chanim_init(118): eth7: failed to set chanim_sample_period
Sep 21 16:29:43 acsd: acsd_chanim_init(127): eth7: failed to set noise metric
Sep 21 16:29:43 acsd: acs_start(432): chanim init failed ret code: -19
Sep 21 16:29:46 acsd: acs_check_cap(334): eth7 Error -19 in getting cap
Sep 21 16:29:46 acsd: eth7: Selecting 2g band ACS policy
Sep 21 16:29:46 acsd: acs_get_country(376): get country on eth7 returned -19.
Sep 21 16:29:46 acsd: acs_start(408): eth7: Failed to get country info
Sep 21 16:29:46 acsd: acs_get_rs_info(226): failed to get obss_coexret code: -19
Sep 21 16:29:46 acsd: acsd_chanim_init(118): eth7: failed to set chanim_sample_period
Sep 21 16:29:46 acsd: acsd_chanim_init(127): eth7: failed to set noise metric
Sep 21 16:29:46 acsd: acs_start(432): chanim init failed ret code: -19
Sep 21 16:29:49 acsd: acs_check_cap(334): eth7 Error -19 in getting cap
Sep 21 16:29:49 acsd: eth7: Selecting 2g band ACS policy
Sep 21 16:29:49 acsd: acs_get_country(376): get country on eth7 returned -19.
Sep 21 16:29:49 acsd: acs_start(408): eth7: Failed to get country info
Sep 21 16:29:49 acsd: acs_get_rs_info(226): failed to get obss_coexret code: -19
Sep 21 16:29:49 acsd: acsd_chanim_init(118): eth7: failed to set chanim_sample_period
Sep 21 16:29:49 acsd: acsd_chanim_init(127): eth7: failed to set noise metric
Sep 21 16:29:49 acsd: acs_start(432): chanim init failed ret code: -19
Sadly I could not find anything in the internet about the log, so I hope someone here can help me understand it :)
Thank you very much for your help!
Hello snbforum,
https://www.snbforums.com/threads/ax88u-overflowing-error-log.67203/
Thank you very much for your reply!
I tried to unplug the router for 5 seconds a couple of times, but the error remains...
Is the main unit (router) or maybe one of the nodes the problem?
