BE96U no SSID on Merlin
MBrown2020
Does the Asuswrt-Merlin no longer display the SSID's on the top of the router page anymore? I believe they were there in the stock Asuswrt before I flashed Merlin on top.
I have all three radios with different names enabled. Thanks
Probably your router model (BE series) or your specific model. The SSID shows on a RT-AX86U Pro running Asus Merlin 3006.102.4_beta3.
Edit to add: A BE-92U also doesn't seem to show the SSID at the top, see the screen capture at this link in the 3006.102.4 beta thread.
SSIDs are no longer shown at the top of Wifi 7 devices because Asuswrt no longer is a "single SSID per band" type of setup. The new Network tab lets you configure multiple bands with multiple SSIDs.
