BE98 Single Device only VPN
miker33
Hi All,
I've recently replaced my old AX88 with a new BE98, want to set up VPN to run over NordVPN for a single wired device (which is connected via a shared switch in the house so the device can't be wired directly to a specific port on the BE98).
On the Asus VPN Fusion setup there seems to be no way to not route the hard wired devices through an active VPN (you can't deselect them from the device list when setting it up), is this single hard wired device VPN routing possible on the Merlin firmware (via IP or MAC address) leaving every other device else running as normal? I may be able to run that single device over WiFi since upgrading my mesh too but still don't want the other physically wired devices to run over the active VPN.
Kind Regards,
Mike
Use VPN Director. It routes using the device's IP address so it doesn't matter whether it's wired or wireless.
