I've got a couple of ethernet-only printers to connect to my network. They are not close to any wired jack, nor does it seem worth the trouble to run a cable to where they are. I'd been using a spare wireless router to connect them, but I've retired that gear and don't want to un-retire it. I experimented with a powerline bridge but am less than satisfied with the results, so I'm looking for some more-modern wireless solution.
I know that I could run an ASUS router in media bridge mode and it would do what I need here, but that's overkill from a cost and complexity (= bugs) standpoint. I've lost faith in ASUS' ability to ship non-buggy firmware, so buying more of their gear is not really what I want to do. Does anyone know of recommendable gear that's designed strictly as a media bridge? I browsed Amazon for a bit but what I found was (a) pretty obsolete gear, 802.11n or below, and (b) brands I'd never heard of.
Another approach could be single-client WiFi-to-ethernet adapters, but what I found in that search suffered from (a) and (b), as well as (c) dubious configuration options. I don't use WPS and I don't plan to start here, so there has to be some other way to set up the unit's WiFi configuration.
Any recommendations gratefully accepted.
