Best option to connect my old Elite 360 to wifi? Don't want to use old adapter.
willyburz
Soooo, what is a good option to connect my old Elite 360 to my AX network? I don't want to use the old N adapter, so what's my best option to wire into a good quality adapter that will use my AX network? I know I can hardwire in general, but I already have my Series X next to it hardwired in. I was smart years ago to hardwire the house, not so smart as I didn't do more than one connection per room, lol.
Buy a $10 switch. Plugin the cable that is currently in your Series X, then, plug in a cable into the switch and into each device. Done. :)
I guess I could do that, I already have the house switched up for each room for my gaming systems...Could do a small switch again.
Least expensive option for the maximum bang-for-the-buck!
