homeofwind
I have a AX-86U with update factory firmware. As Merlin 386.1 stable is out, I like to upload it. Can anyone share the best practices to do that?
Appreciate it.
Appreciate it.
Thanks! And great work! Shall I save the current setting first? If yes, just use the "save setting" function or have to note them down before uploading Merlin? I am newbie and not sure the new UI will be similar to the factory one so I can find the setting locations?Upload it, do a factory default reset, then manually reconfigure it.
Thanks for the help! Will uploading Merlin will change mobile app setting at all? How about wifi name, password etc? Do I need to reconnect devices?Download and save the actual firmware that you have running now.
Save a backup config file from the router's GUI.
Save a backup of the JFFS partition from the router's GUI.
Put the above in a save place for (if) you need to get your router up and running again quickly (you would flash the firmware you saved, fully reset the router to factory defaults, import the backup config file and the backup JFFS file you created above, done (less than 10 minutes).
The best method I have found (recently!) till today for 'remembering' any settings is to download Firefox and save each page as below.
Save Settings From Router
The 'best practices', step by step setup you can do on a full factory reset router is outlined in the links below.
Update/Reset Mini Guide
Reset Mini Guide + Control Channel Setup Details
Control Channel Setup 2021
After the above is completed and you have a fully functional and stable router/network, the link below can add security, performance, and other enhancements to your router with the addition of a spare USB drive. I recommend the 128GB Patriot Elite drives or better (I use the 512GB drives myself). The best is to use a 128GB or larger PCIe m.2 SSD in a UGREEN PCIe to USB enclosure (for some, this is the same cost or less to the 512GB drive I use, with much better endurance and better matched to the writes the nand of the drive will be subject to (vs. just a USB 'key').
amtm Step-by-Step https://www.snbforums.com/threads/amtm-step-by-step-install-guide-l-ld.56237/#post-483421
(Note, do not 'install' amtm as suggested in the guide above if using RMerlin firmware 384.15_0 or later).
The following link may be of use too for further reading.
L&LD | SmallNetBuilder Forums
seems the time is quite unpredictable-may have to do it on weekends-can't do without wifi during day time.Just flashing the firmware shouldn't change any configuration settings you have made.
Just note that it could be 5 to 60 minutes (changelog, RMerlin), up to 3 hours (various), and even 15 hours (@pirx73).
No matter how long it takes, the wait will be worth it (the takeaway is; give it the time it needs before judging it).
Release - Asuswrt-Merlin 386.1 is now available | Page 18 | SmallNetBuilder Forums (snbforums.com)
Is there any reason to use Firefox over a Chrome based browser (Brave, Chrome, Edge, etc.) using Save Page As (Ctrl-S)? Or should this suggestion just be Save Page As in browser?The best method I have found (recently!) till today for 'remembering' any settings is to download Firefox and save each page as below.
@zd59 you may have missed my post above. Very 'verbose' and explicit steps, I think.
Best practice to uploading latest Merlin 386.1
I have a AX-86U with update factory firmware. As Merlin 386.1 stable is out, I like to upload it. Can anyone share the best practices to do that? Appreciate it.www.snbforums.com
@JohnD5000, why are you replying to my post to @zd59?
I replied to you two minutes before your post (look above).![]()
Welcome To SNBForums
