Scoty
Hey all, I could not find a concrete "SSD tech/brand" recommendation thread so I thought I would start a new one. I am currently using an old SONY 16GB flash drive, but I have read the "horror" stories about using flash drives instead of SSDs, so I plan to purchase one to replace it before it breaks.
My first options is a Transcend Portable SSD ESD310C 256GB, which I do not use very often, however it is the same form factor as pen drive, so I wonder how reliable it could be...
My other option is to buy a cheap NVMe (e.g. Patriot - P400 LITE - no DRAM, but w/e) with a cheap enclosure (e.g. UGREEN NVMe M.2 USB 3.2 SSD Enclosure, which will have the speed, but 40GBPs options start from 60-70EUR, so no thanks), ofc I won't get full USB Gen3 2x2 speeds. One thing that worries me is that I have read some reviews and seems that the auto power save feature on this enclosures might cause problems.
My third option is to just buy "cheap" external SSD already enclosed, but they are twice as slow compared to the above option and in most cases more expensive.
What would you do, it you were in my shoes?
