Mohammad Wahiduzzaman
Asus merlin recommends resetting to factory default after flashing to a firmware that is 3 releases older. so I try to reset after every 3rd firmware update. is it ok to backup settings & use that after every reset or does that defeat the purpose? or should I take a note/screenshot of all the changes I made & change the setting manually? I am asking this because i have made so many changes to make the router work properly/ the way i want that i am bit scared to reset
