thelonelycoder
Part of the Furniture
This is a Beta thread. The regular release thread is here.
Please post only Beta related topics here. Thanks.
In order to test new features before they are released, I decided to post a public beta version.
This will be a permanent place for AB-Solution 3.x beta testing.
Announcements for new beta versions will only be made in this thread.
December 09 2017
AB-Solution 3.11 is now available through the beta and release channel
Use cu to update.
This concludes beta testing for now. Thanks for participating.
How to enable beta in AB-Solution
- enter beta into the AB UI
- continue
- select "Set which URL to use"
- select "Set beta URL"
- enter the following:
- then a test is done if the URL is valid and if so, AB now uses the beta channel for all cu and other operations
- enter cu into the AB UI to update all files to this beta version
In the beta menu is an option to use the hosts files stored in the beta channel. You do not need to enable this as we are not testing the blocking file updates in this version.
But you may enable it, the hosts files are up-to-date.
When beta is enabled, the AB UI header adds beta to the version number and the beta URL line:
How to disable beta in AB-Solution
To reset to the standard release location, enter the beta function again and select reset to standard URL.
It will ask you if you want to re-download all files. You can do that, but there's a small bug. It will only download the main file (ab-solution.sh) and not the addon files.
You can either then run cu or enter 1233 to re-download all files from the release channel.
Note that you will loose features not yet released in the release channel.
December 09 2017
Use cu to update.
- continue
ab-solution.info/beta
