RMerlin
Asuswrt-Merlin dev
Asuswrt-Merlin 380.62 Beta is now available for all supported models. The focus of this release was on bug fixing and webui tweaks.
No factory default reset is required if coming from a recent release. There has been no change to the GPL, and no change to the wireless drivers either (before someone asks).
The highlight of what was changed since 380.61:
Things that need particular attention while testing:
Please focus your posts on this specific release, and always specify what router model you are using. Off-topic posts will be either ignored, moved or deleted, depending on my mood at the time.
Downloads are here.
Changelog is here.
- Added the nano editor to the firmware. This is a more user-friendly text editor than vi, making it much easier for people to write custom config files and user scripts. Just type "nano file-to-edit" to edit a file. You can find the online manual at https://www.nano-editor.org/docs.php . ARM routers also have the built-in help included, which can be accessed by pressing Ctrl-G. Note that some features were disabled for the RT-N66U and RT-AC66U, to reduce the amount of space used by it.
- Updates to OpenVPN (2.3.12), nettle (3.2 - used for dnssec crypto) and minidlna (1.1.6).
- Passwords are no longer shown by default on the PPTPD/OpenVPN server pages (there's a checkbox to reveal them). Also, the WPA key will be hidden on the Wireless configuration page, unless you click inside the WPA field to edit it.
- The Wireless Log page was redesigned, allowing to fit the client's IPv6 address in there (if they have one), and displaying longer hostnames.
- Numerous resource leaks were fixed in the networkmap service, as well as a few potential buffer overruns.
- Fixed data corruption when configuring an OpenVPN/PPTPD user or password longer than 32 characters
- Fixed broken IPv6 on MIPS routers if you enabled SSH's brute force protection. Also fixed IPv6 lease renewal with some ISPs with broken DHCP implementations.
- You can tell the router not to issue a prefix RELEASE command at shutdown time for IPv6 (required by some ISPs to ensure you retain your delegated prefix after a reboot)
- Fixed modifying Smart Connect configuration on dual band routers, such as the RT-AC88U.
- Added support for providing a vendor class ID on the WAN DHCP configuration (required for some ISPs)
- Many additional fixes - see the changelog for details
- On the RT-AC88U/AC3100/AC5300, the IPTraffic database was using the wrong filename, using "000000000000" in place of the actual MAC address. You will need to either rename your tomato_cstats_000000000000.gz database to the correct name (replacing the 0's by the router's MAC address, in lowercase), or generate a new database under Tools -> Other Settings.
- See if the numerous fixes to networkmap also resolved issues that a few users were experiencing where their client list came up empty.
- Ensure there's no new issue with the Wireless Log page, especially for IPv6 users
- See if there's any change in behaviour with minidlna
Downloads are here.
Changelog is here.
