RMerlin
Asuswrt-Merlin dev
Howdy folks,
This will be just a quick test run to ensure that nothing is broken, as I'd like to push this release out within a few days. Normally I would have made it just a point release, but since I had already bumped the revision to 384.17, it was faster for me to just push it as-is rather than fork out and cherry-pick a couple of fixes.
It contains only a couple of updates, including an OpenSSL security update that affects TLS 1.3.
I have uploaded the files to the test build folders:
http://www.asuswrt-merlin.net/test-builds
The list of changes:
Please confirm that everything is still working properly (and don't forget to mention which router model you tested).
384.17 (xx-xxx-xxxx)
- NEW: Add Chacha20-poly1305 support to dropbear (themiron)
- UPDATED: dnsmasq to 2.81-openssl (themiron)
- UPDATED: openvpn to 2.4.9.
- UPDATED: curl to 7.69.1.
- UPDATED: openssl-1.1 to 1.1.1g (themiron)
- UPDATED: nano to 4.9.2.
- FIXED: RT-AC88U/RT-AC3100/RT-AC5300 could fail to upgrade
from newer stock versions to Asuswrt-Merlin.
- FIXED: Various webui issues with sorting DHCP reservations.
384.13_7 (xx-xxx-xxxx)
This release is only available for the RT-AC87U and RT-AC3200.
