[Beta] RT-N66U_3.0.0.4_378_8671
this fw is totally broken eg. can't set wifi password.
no special characters i try for test 1234567890 and other simples pass like qwerty etc., i try setup using vizard and can't save configuration when pass is writed. Without password work ok with open system.
Under wireles tab i also try set pass but still can't.
maybe file is corruptet becouse is uploaded without compresion (zip rar) ?
btw. i try also 4g usb e3372 but not work (not in list supported devices)
RMB and save as. If You want i can share printscreen from my 66u.
I can't get it to download.
I can download something - but its a simple 28MB trx file, RT-N66U_3.0.0.4_378_8671-g9c00d75.trx with no release notes or shasum. It is not compressed so you do not even get a simple check of integrity when unzippping it.
I'm sure it was well intended, but I would wait until there's an official beta posted to this forum with version number starting with 9 - or they may well go straight to a release with the later build version others are getting.
CRC32: 4776CCE3
MD5: 052E7D74DD550A0100EA86B15819BD52
SHA-1: 63FC2829F3F2824E24292D2E81E5009CD45B8ED1
SHA-256: FA61153EA8D01190EB02570D6DD34176D137D193C98800073A796DEF8AE4061C
I've been using it almost a month now without issues, so I think these are valid checksums.
I can confirm the md5:-
052e7d74dd550a0100ea86b15819bd52 *RT-N66U_3.0.0.4_378_8671-g9c00d75.trx
