better replacement antennas on ac68u?
freeza
hey guys... wondering if anyone has replaced the antennas on the Asus ac68u and if it is worth doing?
simple answer is yes there are higher gain antennas , is it worth it prob no
if you are not getting adequate wireless coverage from the 68u as it is your are not going to achieve much more by adding higher gain antennas and its prob time to look at running ethernet and a second wireless access point in the area that is not getting good coverage
