Block routed clients if tunnel goes down?
mrmason
I have Client1 and Client2 VPN connections configured on the RT-AC56U router. Both Client1 and Client2 are connected to different VPN Servers and are always both up.
For each client, redirect internet traffic is set to Policy Rules (strict) and I selectively add the unique IP's to tunnel through each client. I tunnel 2 IP's through Client1 and 2 IP's through Client2 respectively. All other traffic is on the Wan.
It's most important that the kill switch works for Client1 and so I set the "Block routed clients if tunnel goes down" to "Yes" for Client1.
For Client2 "Block routed clients if tunnel goes down" is set to "No".
I'm unsure if I set this up correctly to ensure if Client1 goes down, then all traffic for Client1 should be killed?
Hoping the community can provide clarification. Thank you!
