Blocking camera from outside, but enabling with VPN? AX88U
LaMpiR
Hi good people!
I am trying to improve my home security and part of it would be to block the tapo cameras from internet, but would like to connect to vpn and then be able to access them.
I have tried the simplest method found, just using the block internet in the asus app, but I am not able to access it when using vpn to my router. Parental controls, adding there and blocking, the same. In the VPN settings, the option "Client will use VPN to access" is set to "both".
So, please help on how can I block the device from being exposed to internet (Tapo App or anything) and being able to use it only when connected through VPN or the local wifi?
I AX88U with the latest merlin firmware and skynet.
After this, upnp research and restricting plex access and such stuff, but that is to come.
Any help is appreciated.
Hi good people!
Turn off UPnP if it is enabled. The firewall will block access from the outside unless ports are opened. Not a good idea to block the cam access to the internet unless you run the time server on your router. The cam and other clients need to have access to a time server.
My cams record to a Zoneminder server running on a Linux box. I access that server via a VPN when remote. There are many ways to access clients on your LAN. Find the method you are most comfortable with and that you feel is secure.
