Bricked RAX50
liqili2005
My first ever post of SNB so please go easy on me.
I have a Netgear RAX50 and I tried to flash a merlin firmware however thing's going well with the new firmware and it didn't boot. Then I hooked up the serial cable and entered the console and I saw it stayed on a line showed as below. Then I typed some default value and it went to the cfe commnad line. Then I enter the command - reset and the router rebooted then it seems bricked(stopping at a line saying wrong memory size specified) as shown in the second photo.
My router has 512MB ram and 256MB flash but it seems the CFE was misconfigured as 8GB ram. I just flashed the firmware and I can't figure out why it can alter the CFE config. The reset button doesn't work at all. I also can't find the JTAG port. I also attached the photos of the board.
Any advice or help is appreciated. Thank you in advance!
You cannot flash/use RMerlin firmware on non-ASUS/NETGEAR routers! Who gave you the stupid idea to flash your RAX50 with Merlin's firmware?
Well - you're probably toast at this point - if you're in warranty, I'd reach out to support and play dumb - "used to work, now it doesn't"
If you don't have a backup for the CFE, you're done unless someone can source one, and then go into rescue mode and load up the netgear firmware - that should get the router up and going, but there's a good chance that you've smoked the RF cal info along the MAC addresses and other useful things.
I do have the backup of mtd0 partition, but I don't have a way to flash it. If I can find the jtag port that would be easy. Currently there is nothing mentioned online about this chipset and it's a black box to me.
I totally bricked my RAX50 using the Netgear IOS app. The router has a build in firmware flash sequence supported by hardware rom (no-flashable = still working after bad flash). Look at the links in this thread: https://community.netgear.com/t5/Ni...wk-RAX50-when-upgrading-firmware/td-p/2116139
You need to pay attention to my last comment in the thread. Timing is everything when trying to flash. I needed some attempts before I got it working.
If you really really really want to run Merlin, this Chinese site has working firmware (I am running it). I figure out that the chinese is already controlling my routers so what the hell. https://fw.koolcenter.com/KoolCenter_Merlin_New_Gen_386/Netgear/RAX50
I flashed the 5.2 chk file.
I have run it in both router and access point mode with great success.
Using Asus firmware non-Asus router is forbidden, including discussion related to it. You can read more about it here
As others indicated, Asuswrt and Asuswrt-Merlin are only legally usable on Asus routers. Discussions on running it on other manufacturer's hardware is not allowed on these forums. Locking this.
