I have a strange issue: I have a server behind the router. I have the necessary ports mapped via port forwarding.
If the server is accessed from outside (from internet), everything is fine.
If the server is accessed from inside the LAN, it's (almost) mandatory to access it ONLY via local IP. If accessed via FQDN, the response of the server to LAN requests are extremely slow (the public IP has a fully qualified domain name, registered in a public DNS).
So, accessing the inside server xxxx.domain.com from internet it's ok and very fast. Accessing the same xxxx.domain.com from LAN it's extremely slow, almost impossible to access. But if it is accessed from LAN directly via LAN IP of the server, it is very fast again.
I've tried to play a lot with firewall, with MAC and IP address mapping, with WAN settings, no success. Any ideea if I'm doing something wrong?
Thank you very much,
(I've found a way to temporary solve the problem, by modifying hosts file in my PC, and I've mapped FQDN xxx.domain.com to 192.168.x.x, but it's not a real solution)
