BT HomeHub subnet issue
Jamieuwic
I would like to use a different subnet internally than the subnet used by my BT broadband router.
I have a Cisco switch with 2 vlans, Vlan 10 and Vlan 20. Vlan 10 is internal vlan 20 is external. Vlan 20's ip address is 172.16.50.2 Vlan 10's address is 192.168.10.2.
The BT router has a leg in vlan 20 and it's IP is 172.16.50.3. Any PC in vlan 20 can access the internet fine. If a PC is in vlan 10 it can't access the internet.
I have route 0 on the switch which sends 0.0.0.0 0.0.0.0 vlan 20.
I'm pretty sure the issue is with my BT home hub. If someone could find the time to help I would really appreciate it.
J.
I assume your switch is running in layer 3 mode because you have a default route and not a default gateway. I would change default route to point to the IP address of the BT broadband router which I think is 172.16.50.3. I assume the Cisco switch is doing the VLAN routing so the port connecting the router should be an access port not a trunk port. This info is not stated. You need to have a route statement on the router for VLAN10 pointing to the switch.
Thanks for the reply coxhaus.
Everything you have assumed is correct. I have tried pointing the default route to the bt router but it didn't work.
J.
J.
Pointing the default route is only half of equation as you still need to have a routing statement on the router for VLAN10 pointing to the layer 3 switch. If you don't have both it will not work.
