[BUG] 380.57 - Switch Control Option
muffintastic
Hello.
Since the update on my rt ac68u in LAN>SWITCH CONTROL it defaults to CTF and Black Ops III on my Xbox One will not connect to the servers (NOT XBOX LIVE, THAT WORKS) also the Twitch App will not connect also. I have tried setting it to OFF so the NAT is processed by the CPU and still doesn't work.
This is a bug in previous version of the custom-firmware (RT-AC68U_378.56_2), the version below this one. The only work around is to have set to 'Auto' meaning CTF and another option is enabled to get everything working again, but if I again disable the option nothing works, or half the websites work or games.
Could someone shed some light on this problem?
Yes, I've done a clear nvram, and inputted all previous data manually, static IPs and firewall rules. For the time being I will have to revert back to the old CFW to get internet connectivity back to normal...
