Only the 1st OpenVPN works [SOLVED]
stevieosaurus
Found an issue in version 384.19:
Same VPN client configuration (TCP / UDP) always works when it is the 1st VPN in the list, but the EXACT SAME config will not work loaded and activated on any other position.
To specify: connection to the VPN server is always successfully established, both public and local IPs are received, but internet access is only available when the 1st position of the list is the one active. Testing was made only with one OpenVPN connection active at one time, never multiple. Tried it with multiple VPNs, protocols, ports and countries, same result: only the 1st on the list works. Any suggestions?
Worthwhile mentioning: the exact same configuration shows a public IP when it is the 2nd, 3rd, 4th or 5th in the list (and no internet connection), but shows "unkown" when it is the 1st on the list (and internet works). IPv6 has been manually disabled in all cases.
Did you reboot between tests?
You cant use same port on all clients. If you have block internet access on all clients then 1st on will be prioritised. No need to reboot between tests.
That is exactly why I specified that only one connection was tested at one time. No prioritzation was applied since only one connection was active at one time.
Check the System Log for clues. You can also adjust verbosity to 4 and up to get additional debug msgs.
you have the killswitch enabled for client 1, with the same clients routed (or all traffic) don't you?
Yes, I have a killswitch for all of them. But again, the previous services are off. Only one on.
Works for me, my test RT-AC66U_B1 actually has client 2 permanently connected for test purposes. The issue is with your setup.
the firmware doesn't know the difference between the client being switched off, or the tunnel being down. disable the killswitch on 1. does connectivity now work on 2?
Darn it! You were right @Jack Yaz ! The firmware doesn't know the difference and just parses all 5 OpenVPN settings no matter what, in ascending order. If ANY previous of them have killswitch enabled, the internet doesn't work, even if prev. VPN connection(s) are set inactive/disabled.
Thank you so much! What do I do with the tread now? Delete it or leave it for future reference?
