GUI Window Zooming Issue - Minor
n9nu
I noticed this under/in the Wireless--->Professional options page. All other pages are fine.
Accessing the AX-11000 GUI via an Android based phone [S23 Ultra] is simple however the Professional page under the Wireless option cannot be zoomed into as by using the usual method [2 fingers]. It zooms in a bit then stops. All other pages are zoomable to a much higher degree.
Absolutely not a functional bug or anything major; just a lite issue for some phone users.
I don't know if it's an Asus coding issue or a Merlin mod issue as that page is included within the OEM Asus firmware.
Coukd someone with another phone model or make check to see? If you notice you can zoom in considerably more on the other tabs [Roaming Block List] or [RADIUS] .
Just FYI
Tim
ARS N9NU
P.S. I code, so if need be I can snag the source code and take care of it if needed.
Just FYI
Tim
ARS N9NU
I observe the same on my RT-BE88U running 3006.102.5_beta1, but it's not really a problem as it zooms enough to be perfectly readable/usable (not so much a bug).
Hi
Okay. Yeah I don't have any issue reading it either. I guess it's more of a UI oversight.. lol. Tnx for checking. I'm gonna revise the topic heading.
Tim
