Build-380-66-Beta4 with PIA
jjbine
I'm stuck. ASUS RTAC56U.
I copied Yorgi excellent example to my Server and client with no success. Under VPN status, Server 1 is RUNNING, Client 1 is Connecting... (us-east.privateinternetaccess.com udp:1198).
Below is my System Log.
Aug 2 18:13:59 rc_service: httpd 474:notify_rc start_vpnclient1
Aug 2 18:14:15 openvpn[18670]: Options error: You must define CA file (--ca) or CA path (--capath)
Aug 2 18:14:15 openvpn[18670]: Use --help for more information.
Aug 2 18:15:48 rc_service: httpd 474:notify_rc start_vpnclient1
Aug 2 18:16:05 openvpn[18742]: OpenVPN 2.4.1 arm-unknown-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD] built on May 4 2017
Aug 2 18:16:05 openvpn[18742]: library versions: OpenSSL 1.0.2k 26 Jan 2017, LZO 2.08
Aug 2 18:16:05 openvpn[18743]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Aug 2 18:16:05 openvpn[18743]: RESOLVE: Cannot resolve host address: us-east.privateinternetaccess.com:1198 (Name or service not known)
Aug 2 18:16:05 openvpn[18743]: Could not determine IPv4/IPv6 protocol
Aug 2 18:16:05 openvpn[18743]: SIGUSR1[soft,init_instance] received, process restarting
Aug 2 18:16:10 openvpn[18743]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Aug 2 18:16:10 openvpn[18743]: RESOLVE: Cannot resolve host address: us-east.privateinternetaccess.com:1198 (Name or service not known) <----what does this mean? I know it is a valid location.
Aug 2 18:16:10 openvpn[18743]: Could not determine IPv4/IPv6 protocol
Aug 2 18:16:10 openvpn[18743]: SIGUSR1[soft,init_instance] received, process restarting
My client 1 setup is...
My OVPN file is ..
client
dev tun
proto udp
remote us-east.privateinternetaccess.com 1198
resolv-retry infinite
nobind
persist-key
persist-tun
cipher aes-128-cbc
auth sha1
tls-client
remote-cert-tls server
auth-user-pass
comp-lzo
verb 1
reneg-sec 0
disable-occ
Any help would be appreciated.
Jim
ps..note the
My OVPN file is ..
client
dev tun
proto udp
nobind
persist-key
persist-tun
cipher aes-128-cbc
auth sha1
tls-client
auth-user-pass
comp-lzo
verb 1
reneg-sec 0
disable-occ
Jim
ps..note the
Try this.
1. Change Auth Digest to SHA1
2. Change Ciper Negotiation to Disable
3. TLS Renegotiation Time to 0
4. Redirect Internet Traffic to All Traffic
and finally, click on the yellow highlighted text (content modifications to keys and certificates) to the right of the authorization mode field. Verify that you have copied the certificates in the right fields per PIA instructions.
With 380.66 Beta 5, all you have to do is import the ovpn file provided by PIA, click on Keys & Certificates, paste the CA and the CRL content (the files are in the PIA zip), and you're done. Every required setting is automatically imported.
Thanks. I don't see Beta 5 for my router 56U Never mind found it on Mirror2. I'll give it a try. Thanks
