No buying guides. But give these articles a read.Is there any buying guides or advice on the form, to use with my Fire TV, to stream my 720/1080p movies over my NAS? 5GHZ is getting a lot of buffering.
What is your setup (router, location, obstacles)? What kind of content are you streaming (bit rate matters, not resolution)?
If you are looking at homeplug suggestions, most should be able to stream 1080p. You should really only need 15Mbps for decent streaming of most 1080p content (other than bluray). So something's gotta be going on if you are getting lots of buffering with 5GHz wireless (unless you've got a number of heavy users, or high attenuation).
HD1080p is OK with a good strong WiFi signal. But you and your neighbors will compete for unused air time on/near a WiFi channel.
Best to stream video on wire, except for Netflix and the like, as they reduce the data rate cleverly, to fool the eye.
HD1080i, I say, takes ethernet cable.
These are not NAS topics - they're LAN/.WiFi topics.
Welcome To SNBForums
