Fantasyonly
Hey guys,
I’m completely new in this router world, used my provider device before but I thought it would be cheaper to buy one instead of paying a monthly fee and the provider device doesn’t support VPN, so I was searching for routers which support Wireguard, a lot of people are saying that Asus Routers are the best choice because of the software, so I thought I would try them out.
At the moment I could get the AX11000 for around 250 $, its in sale here. The AX86U is 300 $ and the AX88U is 370 $ in my region.
I would like to use the router for my 60 m2 flat, 4 lan ports would be enough for me, so I guess I wouldnt go for the AX88U.
I saw that ASUS got Wireguard support in beta, would love to use this on the router because my Apple TV doesn’t support VPN and I would like to use some other devices through VPN.
Was reading on this forum that some people don’t recommend the AX11000 because it’s not stable and the AX86U is more used. My internet speed is 500 Mbps down and 25 Mbps up, are the Asus routers able to reach that speed? What do you think will they be able to reach with Wireguard as speed?
So, would you go for the AX11000 for that price or pay more for the AX86U?
