BWDPI & Kernel Messages
spykos
Hi all
I am getting below messages in my AX86U (v3004.388.7) almost every 20secs. I noticed them after performing a restore to factory default.
Are these harmless ?
May 11 21:48:00 kernel: SHN Release Version: 2.0.1 21224-01
May 11 21:48:00 kernel: UDB Core Version: 0.2.20
May 11 21:48:00 kernel: Registered DNS Req parsing
May 11 21:48:00 kernel: sizeof forward pkt param = 280
May 11 21:48:00 BWDPI: fun bitmap = 3
May 11 21:48:11 BWDPI: force to flush flowcache entries
May 11 21:48:11 kernel: udb_core lock_num = 5
May 11 21:48:11 BWDPI: rollback fc
May 11 21:48:11 custom_script: Running /jffs/scripts/nat-start
May 11 21:48:11 custom_script: Running /jffs/scripts/firewall-start (args: ppp0)
May 11 21:48:20 kernel: SHN Release Version: 2.0.1 21224-01
May 11 21:48:20 kernel: UDB Core Version: 0.2.20
May 11 21:48:20 kernel: Registered DNS Req parsing
May 11 21:48:20 kernel: sizeof forward pkt param = 280
May 11 21:48:20 BWDPI: fun bitmap = 3
May 11 21:48:38 BWDPI: force to flush flowcache entries
May 11 21:48:38 kernel: udb_core lock_num = 4
May 11 21:48:38 BWDPI: rollback fc
May 11 21:48:38 custom_script: Running /jffs/scripts/nat-start
May 11 21:48:38 custom_script: Running /jffs/scripts/firewall-start (args: ppp0)
This looks like what you might see when navigating to the Bandwidth Monitor page while Adaptive QoS is turned off.
Do you have AiProtection enabled? Those look like the trend micro entries.
BWDPI is used by other processes. Go to Administration>Policy and Withdraw your consent from all the options. Reboot and the BWDPI messages will be no more
