Installing a patch panel for a pretty small office, this will be the first time i have done this (just a trainee), so ive come here to ask you guys for some advice on numbering my sockets up with the right cable on the other end that will go to my patch panel, ive tried just using a enhanced network cable tester and using a small network cable from it to one of my sockets on the wall, then by rights if i short out the cable at the other end i should get some lights on my tester, that was my first solution to matching them up, but when i tried it i had no luck
, is there an easier way of finding out what wall socket is which cable on the other end?
thanks,
David
thanks,
David
