Can I add an AP node to my Asus Mesh?
GabrielPhoto
So I have two AXE16000 in wired mesh configuration and wanted to try adding one extra router (axe11000) as a wired AP .
Is that possible?
thanks
Is that possible?
Yes. It can be added as AiMesh node or as router in AP Mode. If your preference is AP Mode - run it on different channels than your AiMesh if possible, disable the radios you don't need and/or adjust the Tx power for the coverage area you need. If your 2x AXE16000 routers provide adequate coverage already - don't add this AXE11000, it won't make your Wi-Fi better.
