Can I enable WiFi guest network without interrupting the existing ones?
zzz
On Asus RT-AX88U (Merlin 384.19) I am using 3 guest networks at 5GHz.
I set Access Time on one of them, so it gets disabled after the fixed time. When next time I enable this network all other guest networks seem to be rebooted. So, all the connected devices get disconnected for some time which is very inconvenient.
Can I somehow enable 1 guest network without interrupting the other ones?
Unfortunately no when you enable or disable guest wifi, router has to restart the radio. Which causes all 2.4 and 5 to disconnect for few seconds.
Thanks, Hawk. This is unfortunate, but OK, have to live with that.
