S
sorinut
Guest
I have switched to t-mobile home as my primary provider (vs Frontier 3mbit DSL). Problem is, the connection is behind a NAT.
My VPN provider, Windscribe, has a plan with a static IP address and up to 10 ports that I can forward and that I use Merlin to connect to as a client. I'm wanting to connect to my NVR to check my cameras on port 37778. I opened it up on Winscribe and I can't connect to the NVR. I tested the port and it's open from the outside.
Do I need to forward the port from the client VPN to the internal IP address? Can I?
