Can I make my office VPN work automatically via AC68U?
wahoowad
We use some kind of Big-IP VPN solution at work and I normally initiate via a fat client or web client from my home PC. I then provide a token to authenticate. Is there any way to use the VPN config inside the AC68U to establish the VPN when needed?
I'm pretty sure the answer is no...makes me wonder how others use the VPN feature? I would think most VPNs want some type of on-demand token or otherwise to authetincate.
There are many different VPN technologies, none of these are compatible between one another. Asuswrt supports PPTP and OpenVPN - chances are that your office uses neither of these.
G ASUS AC66U_B1 as a VPN Server on LAN ASUS AC Routers & Adapters (Wi-Fi 5) 2
