Can I use web interface to downgrade a John's fork firmware version
lfbb
I'm having troubles with reboots every day on 49E4 in repeater mode, so I'd like to downgrade to an older version. Can I do it through web interface? Router is RT-N66U.
Yes you should be able to. You might need to reformat the jffs partition if going back a long way. A factory reset would also be advisable.
Ok, thanks, I think I did it. I flashed 32E4 but I'm getting errors in system log (repeater mode):
Jan 1 00:00:07 syslog: module ledtrig-usbdev not found in modules.dep
Jan 1 00:00:07 syslog: module leds-usb not found in modules.dep
Jan 1 00:00:44 watchdog: restart httpd, process not found
And this ones in AP mode (second router):
Jan 1 01:00:07 syslog: module ledtrig-usbdev not found in modules.dep
Jan 1 01:00:07 syslog: module leds-usb not found in modules.dep
Jan 1 01:00:08 syslog: module cdc_wdm not found in modules.dep
Jan 1 01:00:08 syslog: module qmi_wwan not found in modules.dep
Jan 1 01:00:08 syslog: module cdc_mbim not found in modules.dep
Are this bugs from 32E4 or I did something wrong? Are the routers going to work fine with these errors?
