Cannot access router page
Amacron
I cant access the routers main page. 192.168.1.1 used to work but now doesnt. Any ideas. I have reset the router but nothing seams to work.
What is the IP of your computer?
IP is 192.168.1.155
it is a IPAD. When I enter the router address it goes blank. If I enter it again the address bar does a super quick update and the page is still blank. I am running firmware 30. I am in the process of updating to 31.
I would suggest clearing the safari cache and make sure you are not running 'private browsing' - smells like a safari issue.
As further proof, might be worth checking from another device (smartphone, laptop etc)
I can access it frmom my imac which is wired in. I was able in firmware 29 but for some reason version 30 and 31 i cannot. I ave turned private browsing off and reset he safari cache but no luck. Any other suggestions?
I have also downloaded chrome on the ipad but still cannot acccess it.
Thanks in advance for the help
I have down some more investigating. I can access it from my imac which is hard wired in. I cannot access it through the wireless connection on my laptop, my ipad or my wifes ipad. I have connected my windows laptopmto the wired connection. And it cannot find it either. I plug it back into my imac and it works. Go figure.
I finally had to reset the router of factory defaults and reloaded merlins build .31 and wala I got the GUI back
thanks to all that tried to help..
