Cannot compile 384.13 for rt-ac86u...
Sylphia
I need geoip function of iptables, so I have to compile the firmware myself. Clean clone from git, built for rt-ac86u.
Found 3 problems:
1. /src/router/openssl built failed, I have to 'make depend' to make it working.
2. /src/router/libevent-2.0.21 built failed, 'autoreconf -vfi' seems fixed it.
3. Unknown reference while building 'httpd': bcmdrivers/broadcom/net/wl/bcm94908/main/src/router/mssl/libmssl.so, SSLv23_client_method, SSL_library_init, SSLv23_server_method, SSL_load_error_strings
I've no idea how to fix the third one, help appreciated.
Make sure you build from the mainline branch.
Do a clean checkout and try again building from mainline - you probably have leftovers from your build attempts on the main branch.
Thanks. I'll try rm all and get a new clone then build.
I've done `git reset --hard` & `git clean -f -d` , I think that was a clean repo... hmm
Confirmed, a clean clone built without any issue.
What's the difference between a clean clone and a repo after `git reset --hard` & `git clean -f -d` :eek:
The problem is the difference in changes of the original .git you had and the ones made to the most recent version on github I suppose. No way to really know at this point since you started fresh. It is this reason I usually always start fresh when I am self building, also I only build if there is a fix that I absolutely have to have or want to test.
