cannot connect to ac88u anymore no dhcp
Mahdi Farhat
suddenly cannot connect to ac88u anymore no dhcp
i rested the router using all the ways mini cfe,30 30 30, i rested the nvram
still cannot connect unless i set the ip manually and it doesn't work all the time (only on first 5 minutes after boot)
log in attachmenets
  • text.txt
Your router is constantly crashing and rebooting itself (it is nothing to do with DHCP).
Try re-flashing the firmware from the CFE miniweb server.
i did reflash using the cfe and the restoration tool.. finished with success but still nothing.
i think it a part of the firmware that is not getting flashed.. because even i tried to flash ddwrt and i got the exact same problem
