So I've had Entware and Rtorrent installed on my AX-88U and working all well until Rtorrent stopped working.
When I try connecting to it via http://192.168.50.1:81/rutorrent/ it says the site can't be reached. I've installed it on port 81 and I know the IP address is the proper one.
I tried reinstalling Rtorrent and Entware. They install properly and I can also see that the Rtorrent process is active, however I can't reach it.
Does anyone have any advice how to deal with this? The easiest way would be to completely delete Rtorrent and entware and their config stuff so I can reinstall fresh, but even that doesn't work, or
I may not be deleting everything properly. I tried wiping the external hard drive via amtm and reinstalling everything, but it still doesn't work.
Thank you
EDIT: Fixed it, so please ignore. Removed everything and reinstalled.
Thank you
