Cannot Login PPTP and no per IP Traffic
suntan
I was trying to login to a PPTP VPN server with my RT-16N router (Firmware:376.47 (Merlin build)) but I am getting a CHAP authentication fail error. I am able to login successfully with my PC on Windows 7 so it looks like its a problem between the router and VPN server. Below is log of the failure. I tried two other PPTP servers but no go on either.
Oct 10 11:13:38 pptp[6284]: Plugin pptp.so loaded.
Oct 10 11:13:38 pptp[6284]: PPTP plugin version 0.8.5 compiled for pppd-2.4.5, linux-2.6.22.19
Oct 10 11:13:38 pptp[6285]: pppd 2.4.5 started by suntan, uid 0
Oct 10 11:13:40 pptp[6285]: Using interface ppp5
Oct 10 11:13:40 pptp[6285]: Connect: ppp5 <--> pptp (67.212.175.124)
Oct 10 11:13:43 pptp[6285]: MS-CHAP authentication failed: Access denied
Oct 10 11:13:43 pptp[6285]: CHAP authentication failed
Oct 10 11:13:43 pptp[6285]: Connection terminated.
But when I try a L2TP server everything works fine.
Oct 10 11:15:47 pppd[6422]: Plugin pppol2tp.so loaded.
Oct 10 11:15:47 pppd[6422]: pppd 2.4.5 started by suntan, uid 0
Oct 10 11:15:47 pppd[6422]: Using interface ppp5
Oct 10 11:15:47 pppd[6422]: Connect: ppp5 <--> l2tp (65.60.11.21)
Oct 10 11:15:47 pppd[6422]: Overriding mtu 1500 to 1400
Oct 10 11:15:47 pppd[6422]: Overriding mru 1500 to mtu value 1400
Oct 10 11:15:50 pppd[6422]: Overriding mru 1500 to mtu value 1400
Oct 10 11:15:50 pppd[6422]: CHAP authentication succeeded
Oct 10 11:15:50 pppd[6422]: local IP address 10.11.1.20
Oct 10 11:15:50 pppd[6422]: remote IP address 10.11.1.1
Oct 10 11:15:50 pppd[6422]: primary DNS address 8.8.8.8
Oct 10 11:15:50 pppd[6422]: secondary DNS address 8.8.4.4
Oct 10 11:15:50 dnsmasq[461]: read /etc/hosts - 6 addresses
Oct 10 11:15:50 dnsmasq[461]: using nameserver 8.8.8.8#53
Oct 10 11:15:50 dnsmasq[461]: using nameserver 8.8.4.4#53
Also when I am logged into the L2TP server I lose my per IP traffic data. (all my IP's show zero traffic but TCP/UDP connections still shows up). The Global traffic monitor though works fine. When I am logged out the per IP traffic data is fine.
Anybody have any ideas?
Suntan
