Folks,
Fairly basic question .. I have a Asus RT-AC68U (T-Mobile converted router ) flashed with Merlin firmware 380.64_2 and I am trying to use it as an Access Point behind an ATT Pace 5268AC gateway (LAN hardwired connection from the Pace gateway to LAN on the Asus router) to get better WiFi coverage inside the house. Once I log into the router using 192.168.1.1 the wizard guides me into setting up AP mode and I give it a Static IP of 192.168.1.250 and DHCP is disabled. I wanted to modify the wireless channels from the default "auto" to "1" for the 2.4GHz band, however I am unable to log into the router again using the 192.168.1.250 address. I am hardwired from my laptop LAN port to the LAN port on the ASUS router. I have tried ipconfig/release and ipconfig/renew and also turned OFF the router and laptop and turned both back ON, however I am still unable to log into the router.
The only way to log back on is to reset to factory defaults by using the physical button on the back of the router and then I can connect to the router on the default 192.168.1.1.
Can anyone please enlighten me on how I can log back onto the router once I set a static IP ?
Thanks!
Thanks!
