Diversion Cannot update Diversion
  • ATTENTION! You'll notice a Prefix dropdown when you create a thread. If your post applies to one of the topics listed, please use that Prefix for your post. When browsing the thread list you can use the Prefix to filter the view.
rrvv
Hello. go this problem when i want to try Updating diversion
Any solution of this problem? if not is there any way for me to do clean install?
L&LD
Part of the Furniture
Try to update amtm to version 3.2 first.
Use uu to do so.
thelonelycoder
Looks like the Diversion config file is corrupted.
Can you post the exact output of this command, entered directly into the SSH terminal:
cat /opt/share/diversion/.conf/diversion.conf
thelonelycoder
Done still cannot access diversion
I got this
Do you have a backup of the file diversion.conf? IE from the Diversion Backup function, local or per email?
To check for presence of the local backup file run this:
find /jffs/addons/diversion/Divers*
If enabled the output would look like this:
[email protected]:/tmp/home/root# find /jffs/addons/diversion/Divers*
/jffs/addons/diversion/Diversion_Standard_local_backup_Jul_10_2021_06.10.00.tar.gz
For the email backup it would contain the diversion.conf file.
rrvv
Doesnt seem available it seem
