CharlieRutledge
I am running an AIMesh network, access point mode, with three nodes. Primary is an AC68U, wired backhaul to another AC68U and to an AC66U. Worked well for a while (well over a year).
All of a sudden, I could no longer access the admin page for the router. Tried multiple browsers, they all give a "can't connect to server" message. When I try accessing via one of the other routers, I get the message "Unable to connect to the Parent AP." This started happening probably a couple months ago, just getting around to trying to troubleshoot. The network is working fine, I just can't get to the admin page. The ASUS Router app on my phone also can't connect, with the message "Unable to use Remote connection." Had used that app for a while too, it was able to connect just fine.
I have power cycled multiple times, to no avail. I am able to ping the primary node, and the wireless network seems to work just fine (which is why I haven't prioritized trying to fix this problem).
I have not tried a factory reset, was hoping to avoid that if I could, not wanting to go through configuring the whole AIMesh network again if I can avoid it.
Wondering if any other ideas about how to access, or things to try other than a factory reset.
Thanks for any suggestions!
