Hexenhammer
Hello,
I have GPON 2.5GB/250MB fiber, they work with their own horrible router, and doesn't have Bridge mode, and I have AX89X, so i bought a fiber module from them, they work only with their own Nokia ones.
First i tested it with the ASUS SFP+ port and it doesnt work, the port only does 1GB or 10Gb, no inbetwen, when i force it to 1Gb i get 1Gb conenction, when i force it to10Gb or Auto it has no connection, I spoke to Asus engineer and they said thats how it is and only in new Qualcomm SDK that they dont use yet and maybe will never update to, tehre are opions for 2.5gb and 5Gb.
So I went out and got new UCY-XT705MC Media converter that supports all MultiGig formats.
AND, it still doesn't work, I have the SAME issue just with the RJ45 10Gb Ethernet port, which is a Multigig port I tested it myself and works fine with 2.5Gb 5Gb, 10Gb and 1GB
Yet when I connect the Media converter, the media converter also has 10gb multi gig port so the connection between router and media converter is 10GB and somehow it affects PPPoE, I cant dial in.
THE ONLY way for me to dial in PPPoE is if I plug into 1Gb WAN and it forces the Media converter into 1GB mode then PPPoE works.
I also have old DLINK 1GB media converter and did a test by connecting it to all 3 ports and PPPoE worked trhough all 3 of them, but it was 1GB of course
Sadly this router has no manual way to change the speed of the RJ45 10GB port.
Any ideas?
Any ideas?
