Can't connect to my openvpn server anymore - Asus AC-RT87U.
NysSD
Since the latest update i'll get this error when i try to connect to my openvpn server:
Jun 22 18:19:10: Viscosity Mac 1.5.7 (1290)
Jun 22 18:19:10: Viscosity OpenVPN Engine Started
Jun 22 18:19:10: Running on Mac OS X 10.10.4
Jun 22 18:19:10: ---------
Jun 22 18:19:10: Nakijken of verbinding beschikbaar is...
Jun 22 18:19:10: De verbinding is beschikbaar. Er wordt gepoogd de verbinding op te zetten.
Jun 22 18:19:10: OpenVPN 2.3.7 x86_64-apple-darwin [SSL (OpenSSL)] [LZO] [PKCS11] [MH] [IPv6] built on Jun 13 2015
Jun 22 18:19:10: library versions: OpenSSL 1.0.2c 12 Jun 2015, LZO 2.09
Jun 22 18:19:22: Attempting to establish TCP connection with [AF_INET]external_IP:443 [nonblock]
Jun 22 18:19:23: TCP connection established with [AF_INET]external_IP:443
Jun 22 18:19:23: TCPv4_CLIENT link local: [undef]
Jun 22 18:19:23: TCPv4_CLIENT link remote: [AF_INET]external_IP:443
Jun 22 18:19:23: WARNING: this configuration may cache passwords in memory -- use the auth-nocache option to prevent this
Jun 22 18:19:23: TLS_ERROR: BIO read tls_read_plaintext error: error:14082174:SSL routines:ssl3_check_cert_and_algorithm:dh key too small
Jun 22 18:19:23: TLS Error: TLS object -> incoming plaintext read error
Jun 22 18:19:23: TLS Error: TLS handshake failed
Jun 22 18:19:23: Fatal TLS error (check_tls_errors_co), restarting
Jun 22 18:19:23: SIGUSR1[soft,tls-error] received, process restarting
Jun 22 18:19:34: Attempting to establish TCP connection with [AF_INET]external_IP:443 [nonblock]
Jun 22 18:19:35: TCP connection established with [AF_INET]external_IP:443
Jun 22 18:19:35: TCPv4_CLIENT link local: [undef]
Jun 22 18:19:35: TCPv4_CLIENT link remote: [AF_INET]external_IP:443
Jun 22 18:19:35: TLS_ERROR: BIO read tls_read_plaintext error: error:14082174:SSL routines:ssl3_check_cert_and_algorithm:dh key too small
Jun 22 18:19:35: TLS Error: TLS object -> incoming plaintext read error
Jun 22 18:19:35: TLS Error: TLS handshake failed
Jun 22 18:19:35: Fatal TLS error (check_tls_errors_co), restarting
Jun 22 18:19:35: SIGUSR1[soft,tls-error] received, process restarting
Jun 22 18:19:46: Attempting to establish TCP connection with [AF_INET]external_IP:443 [nonblock]
Jun 22 18:19:47: TCP connection established with [AF_INET]external_IP:443
Jun 22 18:19:47: TCPv4_CLIENT link local: [undef]
Jun 22 18:19:47: TCPv4_CLIENT link remote: [AF_INET]external_IP:443
Jun 22 18:19:47: TLS_ERROR: BIO read tls_read_plaintext error: error:14082174:SSL routines:ssl3_check_cert_and_algorithm:dh key too small
Jun 22 18:19:47: TLS Error: TLS object -> incoming plaintext read error
Jun 22 18:19:47: TLS Error: TLS handshake failed
Jun 22 18:19:47: Fatal TLS error (check_tls_errors_co), restarting
Jun 22 18:19:47: SIGUSR1[soft,tls-error] received, process restarting
Thanks to the release of 1.0.2a openssl and #LOGJAM. Do the following
#0 Make sure your router has the correct TIME.
#1 in linux run: openssl dhparam -out dhparams.pem 2048
#2 in the ASUS RT-68U go to /Advanced_VPN_OpenVPN.asp and change it to "advanced" on the dropdown
#3 click Content modification of Keys & Certification. Copy Paste your dhparams.pem content into "Diffie Hellman parameters"
#4 Hit Apply. Your clients should reconnect
#6 Credit me when you get points on stackexchange for this, i spent hours reading openssl change logs and understanding what all was done here to break this for everybody.
L Can I connect to wireless networks? Routers 5
